XJ ( X351 ) 2009 - 2019
Rough idle at stops
Old Jan 23, 2019 | 07:30 PM
Rego889's Avatar
Default Rough idle at stops
I have 1998 xj8 non-supercharged with 125k.. I have cleaned the throttle body and put new spark plugs in it..and it is still missing and has a rough idle at all stops.. it also hesitates when pulling away then it smooths out and drives great..can anyone help me?
Old Jan 24, 2019 | 06:36 AM
Stuart S's Avatar
First, get all the OBDII fault codes instead of guessing.
Second, post your inquiry in the proper Forum for your 1998 XJ. This is the X351 current model XJ Forum. You need to be in the X308 model Forum. The list of Forums is here:
https://www.jaguarforums.com/forum/
Old Jun 1, 2019 | 09:46 PM
RobertShaw's Avatar
Check your oil fill cap. If the gasket is bad or the cap not closed properly, the idle will be rough.
mystype04
Apr 11, 2019 08:46 AM
KMT
XJ40 ( XJ81 )
Mar 10, 2017 08:36 PM
93greenconv
Jul 27, 2014 09:04 AM
xjrwithproblems
Nov 9, 2013 02:56 PM
Ipc838
Jun 26, 2012 02:50 PM
