XJ ( X351 ) 2009 - 2019
Ruptured brake line
Old Aug 3, 2022 | 02:30 PM
bullittandy's Avatar
Default Ruptured brake line
2012 XJ, 70k miles. I had to suddenly brake on interstate and the right front flexible line burst. I’ve never had that happen on a car and certainly not on a 10 yr old one, and these are stainless braided lines. Amazing. Anybody else ever seen this on their XJ (or XF)?
Old Aug 3, 2022 | 03:20 PM
rothwell's Avatar
That is an odd occurrence for sure.
Any chance the line got damaged in that spot from a foreign object? I haven't done the brakes on this model yet so not sure how much the lines are exposed to the road.
Burst pressure for one of those lines has to be way above the normal operating pressures the system is capable of. Seems like a weak spot would be needed in the line one way or another. Either from external damage or a material defect. If I had to put money on one of those two my bet would be on external damage as the culprit. I don't see how a material defect could last that long.
Glad you were able to avoid any "serious" result from the failure.
Old Aug 11, 2022 | 04:04 AM
Not sure if it was damaged previously but certainly a possibility.
Old Aug 11, 2022 | 10:09 AM
XJsss's Avatar
looking at the photo it seems a couple of the wire strands and the hole in the line looked like an external object punctured the line.
index1489
Apr 13, 2022 07:24 PM
Mongoose
25
Aug 16, 2021 12:04 AM
yachtmanbuttson
Jun 7, 2020 12:29 PM
bwbowers
Apr 27, 2020 06:13 PM
TN8Shooter
Jun 11, 2011 09:51 AM
