XJ ( X351 ) 2009 - 2019
Side marker replacement
Old Dec 15, 2013 | 10:17 AM
jnockmnock's Avatar
Default Side marker replacement
The right rear side marker on my 2008 Vanden Plas has stopped working and and is filled with water. The dealer wants $428 to replace it, an amount that seems outrageously high. I have found a used one for $80. Does anyone know how difficult it is to replace the side marker?
Old Dec 17, 2013 | 09:05 AM
edobernig's Avatar
Default Move post to 2003-2009 XJ Forum
In the right model year forum, I'm sure you'll get a response.
Old Dec 17, 2013 | 09:08 AM
edobernig's Avatar
Default Move post to Modern 2003-2009 XJ Forum
Old Dec 18, 2013 | 12:31 PM
jnockmnock's Avatar
Ed, my mistake. I'm new to the forum -- this is my first post.
Old Dec 19, 2013 | 08:11 AM
edobernig's Avatar
Default Not a problem.
Just resubmit your question in the jaguar Models (Modern)> XJ (X350 & 358) Forum Section for your car. There are also helpful posts in the How To Section regarding many home maintenance project like oil changes and brakes.
Fortunately I have a 2004 XJ VDP which is similar. You can go to WWW.JagBits.com to find the new part for about $88.00 http://www.jagbits.com/mm5/merchant...._Code=C2C35377
It appears that unit is attached to the bumper cover. I am not sure how to remove it. You may have to remove the wheel and inner fender shield to get at it or the unit is installed from the outside.
Just copy this message and start a thread in the right section. I am sure someone has had to change this or the bulb. Fortunately your are in Phoenix so you can work on this and not be frozen like here in Milwaukee this week.
Sprayall
May 30, 2021 08:13 AM
tberg
Sep 7, 2015 07:32 AM
Sprayall
Sep 3, 2015 07:49 PM
David Thompson
Sep 3, 2015 07:48 PM
johanasu
Sep 3, 2015 12:39 PM
