XJ ( X351 ) 2009 - 2019
Single wipe function not working
Old Jul 24, 2020 | 10:11 AM
Tomwhite's Avatar
Default Single wipe function not working
Hi All,
I wonder if some one can help, the Single wipe function is not working when pulling the wiper stalk on 2015 XJR while all other wiper functions are working normally.
Really appreciate any help
Old Jul 24, 2020 | 03:30 PM
Thermo's Avatar
Veteran: Navy
Tom, from the sounds of things, your wiper stalk has bit the dust and will need to be replaced. The stalk has a little switch in it that when you pull the stalk, it sends power to the motor to make it move. Once the motor is out of its "home" position, there is a switch inside the wiper motor that keeps the power applied until it reaches home again. At that point, the motor looses power until another power pulse is sent.
Old Jul 25, 2020 | 10:00 AM
clubairth1's Avatar
Community Influencer
I agree with Chris. Replace the stalk first and see if it's fixed.
Should be a simple repair too.
Old Jul 26, 2020 | 05:08 AM
Tomwhite's Avatar
Thank you guys for your reply, I will try that and report back, from what I read it doesn't seem to be a common problem on the X351, maybe its one off
Old Aug 3, 2020 | 06:35 AM
Tomwhite's Avatar
Hi Guys, just an update, I booked the car in and it will go next week to the dealer, I experienced something really strange, the other day every thing worked on the wiper stalk then the next day no single wipe function working as well as position 2 for continuous wipe and position 3 for fast wipe was not working, only in position 1 with timing function was working I am now completely lost could this be the problem with the stalk?
Any help is greatly appreciated.
By the way the lighting stalk is in perfect working order every thing work as it should be
Old Aug 3, 2020 | 04:19 PM
Thermo's Avatar
Veteran: Navy
TomWhite, it is still the stalk. It shares a few common wires and depending on what is failing, it can cause randomness like you are seeing.
Old Aug 3, 2020 | 05:10 PM
clubairth1's Avatar
Yes. Change it and report back.
stham
Jun 16, 2017 12:25 AM
welshwoody
Apr 9, 2017 04:56 AM
Lanny Edgeman
Jan 8, 2012 12:58 PM
general specific
Oct 18, 2011 09:59 PM
kiloslanga
Mar 16, 2008 09:52 AM
