XJ ( X351 ) 2009 - 2019
Steering heavy - Servotronic problem
Old Apr 6, 2023 | 12:39 AM
zielins's Avatar
Default Steering heavy - Servotronic problem
I have a problem with steering assist - it is too heavy in every conditions. I have no active DTCs, but there are some in the memory:
U0415-00 Invalid data received from ABS control module (Status: Intermittent)
B12FA-13 Servotronic valve circuit open circuit (Status: Untested)
B12FB-12 Servotronic valve circuit short circuit to power (Status: Untested)
I assume that last two of them were caused by my test - I connected 12V directly to servotronic valve. This results with light steering so the problem is signal from control module to the valve. Wiring up to junction box is ok.
My questions:
1. If any DTC (like this with ABS) causes disturbance of the control of servotronic valve - how to bring it back to action? I think the problem might be short lack of speed signal from ABS. But why steering assist is not restored when signal is ok?
2. Which module controls the valve - is there any method of diagnosis why it is not working correctly?
Thanks for any help or suggestions.
Old Jun 12, 2023 | 09:52 AM
Marko xj's Avatar
Default Too hard steering …
hi, I have the same dtcs, my steering is stiff, did you manage to solve your problem?
My questions:
Old Jun 12, 2023 | 11:59 PM
zielins's Avatar
Unfortunately not.
David N. Warner
Mar 18, 2022 08:26 AM
Fergolf
May 18, 2021 03:20 AM
Maury
Oct 11, 2020 03:46 PM
cat4su
May 14, 2015 05:34 AM
justinb67
May 10, 2010 08:46 AM
