XJ ( X351 ) 2009 - 2019
Thermostat housing Please help
Old Aug 10, 2024 | 03:14 PM
Mack74's Avatar
Default Thermostat housing Please help
I am trying to replace thermostat housing with metal one but thermostat housing will not come out of hose with metal ring is around. Have any one come into a issue with the thermostat housing and if so what's you method of getting it off.
Old Aug 10, 2024 | 11:18 PM
dennis black's Avatar
Use a rubber
mallet and tap all around it will come apart
Old Aug 13, 2024 | 09:00 AM
Mack74's Avatar
Default Thanks
Thank you Sir. I will try. I'm getting ready to put the rear metal coolant pipes on. Should I put a sealant around the gasket for extra precaution or just put them on without any sealant. I have high heat rtv.
Old Aug 13, 2024 | 09:33 AM
clubairth1's Avatar
Community Influencer
No goo on rear water manifold rubber seals. Are you using the correct Jaguar seals?
Old Aug 13, 2024 | 10:32 AM
Mack74's Avatar
Just the seals that came with the coolant pipes
Old Aug 13, 2024 | 12:27 PM
clubairth1's Avatar
Yes. Well it's your car?
I also installed the after market rear water manifold but went with the factory seals. They are way different than just a standard O-ring? Why Jaguar went to all that trouble I am not sure? But O-rings never use any sealer or goo. Lubrication before installation? Yes of course.
Here is what I used on my rear water manifold.
This was after going through a very detailed rear water manifold thread. Not much cost to use the right part after I got the part number.
I also learned in that thread to check the diameter of the fluid passages. They were severely restricted (Tapered down in diameter) and I drilled them out since I also used the two piece manifold so I could split it and check. I had no clue about this until that thread came out either.
Old Aug 13, 2024 | 01:09 PM
Mack74's Avatar
Old Aug 13, 2024 | 01:12 PM
Mack74's Avatar
It's my vehicle. Thanks for the information. Is it ok for me to call on you for assistance.
Old Aug 13, 2024 | 01:34 PM
trkyam's Avatar
I had to remove and replace the hose connected to the thermostat because
I couldn't get it off the thermostat.
Old Aug 13, 2024 | 06:30 PM
Mack74's Avatar
Since I was waiting for the rear coolant pipe part to come in. I decided to go ahead and work on putting in the metal thermostat housing while waiting on the coolant pipe part to come in. Nope it was not happening it would not budge but I'm going to try to mallet and see if it will come off that way.
mpasiuk
Jul 29, 2023 09:58 AM
Grantysx
Mar 8, 2023 10:53 PM
Hazmat1075
Oct 21, 2022 09:09 AM
Stamford
Aug 23, 2020 01:40 PM
ez64
Jul 25, 2011 10:38 AM
