XJ ( X351 ) 2009 - 2019
Time to replace brake pads any recommendations
Old Aug 2, 2017 | 12:02 PM
coxzilla97's Avatar
Default Time to replace brake pads any recommendations
Looking for some brake pads to replace on the rear. Front factory pads still newer. Would be nice to have less brake dust.
Old Aug 2, 2017 | 02:12 PM
JagGate's Avatar
Anything Ceramic. I have used the below brand but not on the Jag. Also have used Wagner and Raybestos.
Amazon Amazon
Old Aug 2, 2017 | 05:16 PM
XJsss's Avatar
My recommendation is if you want to go to a non OEM brake pad you will need to replace both front and rear at the same time since the coefficient of friction needs to be the same. As I have said before in the forum. I used ceramic pads on my 2001 XJR and while they had significantly less brake dust they didn't stop as well as the OEM pads and rotors.
Old Aug 6, 2017 | 09:02 AM
hafren's Avatar
Have a look at this post https://www.jaguarforums.com/forum/x...011-jx-183122/
