So can anyone shed some light on this problem which i still have not got sorted.. so it started after i had the rear wheel passenger side valve changed as it was loosing air and i had to top up every few weeks.
Once i drove away from the tyre shop after a mile or so warning flagged up telling me tyre pressure sensor warning rear left not reading correctly, anyways i left it as thought might be a glitch and might sync it self but after over a week it just stayed on constantly and then started with “tyre pressure system malfunction” fault it was intermittent as some days came back up with reading rear left sensor and said not reading correctly.
Anyways i decided to plunge and get new sensor which is a original jaguar sensor got it fitted and drove for about a hour to sync it but no avail still same fault “ tpms system malfunction” with tyre light flashing rapidly then stays solid. After putting a post on here and advised to read codes from sensor and program it in i did that and checked all other sensors which all were reading as good, could read tyre pressure and air temp from the sensors so all working.. after messing with it on a diagnostics machine and following programming procedure i gave up and left it as nothing was working..
but now i get this warning randomly every few days stays on for about 18-20 miles then reverts back to TPMS system fault! When it first started showing this i went and released all the air in all tyres then re inflated them to 32psi drove it 15 miles and still showing as the above until i get to around 18-20 miles then back to TPMS system fault 🤬😡 its obviously reading the sensors and they are all working but im at a point of what do i do now? I dont have JLR software myself to see if that pics anything up, so back on here for any suggestions from anyone? The sensors and antenna’s are obviously working as it picking them up..
Has anyone experienced this kind of problem? Or help? Thanks
