XJ ( X351 ) 2009 - 2019
TPS Problelm Finally Resolved on 2015 XJ
Old Nov 23, 2025 | 01:40 PM
David N. Warner's Avatar
Default TPS Problelm Finally Resolved on 2015 XJ
Hello,
I want to thank everyone that contributed some ideas to the TPS problem of my 2015 XJL. Turns out it was not the TPS sensors in the tires or the modules that they connect to. It was the front intermediate connector had been compromised and was corroded. C11 is the connector that connects the front TPS receiver antennas to the front interface/ engine fuse box. It appears the connector was not fully seated and water had been seeping into it for some period of time. Once the contacts were scrubbed, sanded, scrapped clean, and sprayed with some contact cleaner and Deoxit, the warning has not appeared after a few days of driving! Not sure if there is a way to view any information relative to the state of the tire pressure in the instrument cluster but at least I don't have that same warning on the dash whenever I start the car.
See photo below. Thanks again! Dave
Old Nov 23, 2025 | 03:18 PM
clubairth1's Avatar
Community Influencer
Good job!
BUT don't leave out "The Rest Of The Story" as they say?
How did you find it?
Old Nov 23, 2025 | 04:58 PM
12jagmark's Avatar
That's great news - at long last!
It might be helpful if you can merge this stand-alone post with the one that was going, so that it is continuous from beginning to end; including the cause, solution and closure.
Old Nov 23, 2025 | 06:19 PM
wombat's Avatar
Thank you for reporting the fix!
My wife once owned an Subaru Outback that probably went back to the dealership 15 times to fix a TPMS snag...It never got fixed! In the end I put a mall piece of black electrical tape over the caption on the dash!
Thanks again and happy motoring!
wombat
Old Nov 24, 2025 | 09:40 AM
Hi Guys, I'll write it up with some diagrams and more info in a bit. Thanks for the idea Clubairth!
Old Nov 24, 2025 | 12:37 PM
clubairth1's Avatar
Hey you deserved a break on this repair! You can do all the right things and STILL not find it.
Old Nov 24, 2025 | 12:41 PM
RoverJoe's Avatar
Great catch, those little green fuzzies in there cause all sorts of issues. Nice to catch something like that so you know it's fixed.
Old Nov 24, 2025 | 06:40 PM
I was an electronics technician in my previous life. Reading schematics and wiring diagrams was daily activity and I just never give up until I fix the problem!
Old Nov 25, 2025 | 09:49 AM
JoshMcMadMac's Avatar
Then you picked the right car!
Congratulations on the fix, that is great diagnostic work.
vwong688
Jan 3, 2024 01:38 PM
ptmead3
Aug 12, 2015 08:08 AM
gmcgann
Jul 15, 2014 07:51 PM
pa-cresta
XJ40 ( XJ81 )
Mar 20, 2014 02:45 PM
SuperSport
Oct 26, 2012 10:13 AM
