XJ ( X351 ) 2009 - 2019
Trying to source BMS 2 wire pigtail
Old Today | 11:33 AM
farm-jag's Avatar
Default Trying to source BMS 2 wire pigtail
I need the pigtail end for the BMS sensor that is on the negative terminal. I have the sensor and it works fine, but someone previously cut the pigtail off the harness Blue+White small wires. I was hoping it was rolling around in the spare tire bay but no such luck. Unfortunately, none of the few local U Pick salvage yards around have any Jaguar models that would have this pigtail so I cannot go source it myself, which would be the cheapest and easiest. On a side note, for some reason my JPart install cannot load the images under the 2011 Jaguar XJ for the Battery and Fixing section, so I am not even sure of the BMS part number. I was just going to try to use that as a reference point to look for something. There is a full service salvage yard that has several models that would have this pigtail, but trying to make them understand what I am after is often difficult, I will use them as last resort, but would like to know if anyone else has any suggestions. I suppose I could just affix the wires directly but that is janky and a last resort. Thanks!
Mike
afransella
May 14, 2023 12:54 PM
LukeShopManager
Feb 15, 2023 07:53 AM
elDariusVargas
Jan 3, 2022 06:58 PM
sawduster
Nov 6, 2019 03:14 PM
Daim
Oct 9, 2016 03:08 AM
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
