XJ ( X351 ) 2009 - 2019
VAP stage 3 rod and piston set
Old Feb 4, 2023 | 07:51 PM
Nedoerr's Avatar
Default VAP stage 3 rod and piston set
I’m not really in the market, but what are people’s thoughts in this? And why would this only work on 2013+? Thanks
Velocity AP piston and rod set
Old Feb 4, 2023 | 09:02 PM
OzXFR's Avatar
Previously mentioned on the F-Type sub-forum, see here: https://www.jaguarforums.com/forum/f...1/#post2608133
My WAG is that VAP intend these for use with their upcoming E85 tune on the V8 (they already have this for the AJ126 V6) and that upgrade/tune only works with the later Bosch ECU and not with the earlier Denso ECU, and the changeover of ECU was in 2012/2013.
Old Feb 8, 2023 | 12:31 PM
clubairth1's Avatar
Community Influencer
I wonder what they changed? No compression ratio listed in their add?
Old Nov 21, 2023 | 12:11 AM
conmao's Avatar
They are exactly what one would need for high boost application/high cylinder pressures.
Currently in the process for building an AJ133 engine and using the new 2300 Harrop super charger. First one in Australia i beleive.
Goal is 900HP
Dibi
Feb 4, 2023 04:48 AM
jaguarxfs
May 14, 2018 03:38 AM
vdpnyc
Aug 5, 2016 07:19 AM
88-xjsv12
Jun 29, 2013 05:56 PM
jason8335
Apr 12, 2011 06:36 PM
