XJ ( X351 ) 2009 - 2019
Vortex Wheels on a XJ X351
Old Jan 16, 2020 | 02:30 AM
XJLR's Avatar
Default Vortex Wheels on a XJ X351
Hello dear Jaguar lovers,
Maybe you can help me and I have one:
Jaguar XJL X351 3.0d
Year of construction 2014.
I could get hold of the Vortex rims.
Front: 9x20 ET49
Rear: 10.5 ET 51.
I think I won't have any problems with the front rims, only with the rear ones, because I suspect that they are too deep in the wheel arch. Stripes in the box will certainly not work.
Only I'm not sure how I can solve this with the wheel spacers, since the rims have no pockets on the inside.
I am grateful for any experience or tip!
And sorry for my poor English - come from Austria.
Thank you!
Old Jan 16, 2020 | 07:18 AM
XJsss's Avatar
Here are the specs for tire an wheel specs that include the offsets. There have been reports that moving away from the recommended offsets has resulted in premature wheel bearing failure. Good luckXJ (x351) 20” Tire and Wheel Tech Specs:
--------------------------------------XJs--------------------------------------- XJR
Front Wheels: Tires 245/40/20”, Wheel 9J, 49 offset --- Tires 245/40/20”, Wheel 9J, 49 offset
Rear Wheels: Tires 275/35/20”, Wheel 10J, 44 offset--- Tires 275/30/20”, Wheel10J, 46 offset
Old Jan 17, 2020 | 01:58 AM
XJLR's Avatar
Vielen Dank für Ihr Feedback, aber was meinen Sie mit vorzeitigem Ausfall der Radlager? Haben Sie die Felgen an einem XJ montiert oder kannten Sie jemanden von Ihnen? Ich dachte, dass ich praktische Informationen im Forum finden würde oder ob jemand diese Felgen auf einem XJ gefahren hätte. Vielen Dank!
Old Jan 17, 2020 | 08:48 AM
XJsss's Avatar
Sorry I don't speak German.
Old Jan 17, 2020 | 09:29 AM
Tahoe Dave's Avatar
Google Translator...
Thank you for your feedback, but what do you mean by premature failure of the wheel bearings? Did you mount the rims on an XJ or did you know any of them? I thought that I would find practical information in the forum or whether someone would have driven these rims on an XJ. Thanks a lot!
Old Jan 17, 2020 | 10:18 AM
Stuart S's Avatar
See: Wheel Spacers
Old Jan 17, 2020 | 10:24 AM
Hank Scorpio's Avatar
I believe what XJsss is saying is that if you use a different offset, either more positive or negative, that could make the wheel bearings fail prematurely because the unsprung weight of the wheel and tire is not sitting on the bearing in the same way as the OEM wheels, since the offset is slightly different.
That being said, the offset seems pretty close, and dozens of people run aftermarket wheels with different offsets, so i wouldnt be too concerned about it, but that is just my opinion.
LaCroix
Aug 25, 2019 09:07 PM
hoopics
May 22, 2019 01:56 PM
Skeggylad
Apr 20, 2017 04:21 AM
jagtoes
Aug 13, 2014 07:08 AM
jagbuff
Mar 23, 2012 05:46 PM
