XJ ( X351 ) 2009 - 2019
Water in fuel reset
Old Mar 20, 2024 | 09:22 AM
Stefanwest1's Avatar
Default Water in fuel reset
Hi all, had the car serviced recently, and since then I've had a "Water in fuel" error. I replaced the sensor today, but the warning is still there. I'm assuming it needs the fault clearing? Is there a simple way to do this without a code reader?
Old Mar 20, 2024 | 10:47 AM
Thermo's Avatar
Veteran: Navy
Stefan, if you truely fixed the problem, after 5 drives, the fault should clear. Each drive will need to be about 5 minutes minimum in length. If it stays on after that, then the problem is not resolved and further investigation is required.
Andy T.
Mar 7, 2024 07:01 AM
Epikuro
Jul 27, 2022 11:21 AM
Lockwood27
Jun 27, 2022 10:06 AM
Ian Mac
Feb 16, 2018 01:17 AM
Bali
Mar 24, 2017 03:17 PM
