XJ ( X351 ) 2009 - 2019
What did you do to your X351 today?
Old May 31, 2024 | 01:40 PM
  #561
XJsss's Avatar
does the float come to the top of the fluid? If no check the collant/water mix as if to much water the float will not rise.
  #562
Meanmugga's Avatar
Finished my ADH camera install. Going to connect the digital mirror next.
Old May 31, 2024 | 01:48 PM
  #563
dmchao's Avatar
Odd. I had that happen to mine, the sensor seems to wear out over time. It's built into the coolant expansion tank, my guess is you can just replace that. It takes 30 minutes or less.
Old May 31, 2024 | 01:54 PM
  #564
Paldi's Avatar
Originally Posted by XJsss
does the float come to the top of the fluid? If no check the coolant/water mix as if too much water the float will not rise.
I don't know where the float is.
Old May 31, 2024 | 02:46 PM
  #565
lotusespritse's Avatar
That's a good idea. I'd like to see how the image looks when you're all done. I am a little concerned the camera is going to pick up a lot of reflection day and night off the white roof and cause an issue with auto contrast.
Old Jun 1, 2024 | 05:19 PM
  #566
Paldi's Avatar
I can't see it. If I look into the tank (cap off) is the float supposed to be right there?
Old Jun 2, 2024 | 12:42 AM
  #567
Meanmugga's Avatar
So far so good. I can adjust the angle of the lens as well.
I will update once I run the wire to the front
Old Jun 12, 2024 | 06:41 AM
  #568
Paldi's Avatar
Dealer replaced one of mine under warranty. If I never use them, could they still eventually break?
Old Jun 12, 2024 | 07:34 AM
  #569
Paldi's Avatar
I'd like to do something like that on mine.
Old Jun 18, 2024 | 11:23 AM
  #570
Vasara's Avatar
I took my XJ to the MOT today.
No markings, exept the crack on winshield, what is ordered but take 2 months to arrive.
Diesel smoke test result was 0,01 what tells that everything is still Ok on my engine, even after 14 years and 316tkm (197t mil).
(been thinking that it start to be time for newer car, but why and if, then what next? )
Old Jun 18, 2024 | 11:45 AM
  #571
Originally Posted by Vasara
then what next? )
Find a well-cared for XJ of the same type, but with low miles, so you can rinse and repeat. Pay the premium for a top notch used one.
Old Jun 18, 2024 | 02:59 PM
  #572
Vasara's Avatar
That have been my mind. Local market is pretty much zero available so import from Germany it is again. Offering gets thinner there too.
Noted that one R575 available with low km, 575:s are super rare on EU market. Bit pricey though, 139k Euro.
https://suchen.mobile.de/fahrzeuge/d...24d4629&vc=Car
Old Jun 19, 2024 | 09:14 AM
  #573
ralphwg's Avatar
I have a 2018 575 that i bought in early 2022 fore $90k. Couldnot open link to compare data. Great car!!! Best Jag sedan yet.
Old Jun 19, 2024 | 10:27 AM
  #574
Vasara's Avatar
mobile.de pages are sensitive for almost anything. Seems like currently Edge browser is only one opening pages. Owned by eBay and they working with the issue.
Aaannd.. i made an mistage on link:
https://suchen.mobile.de/fahrzeuge/d...5f579e6&vc=Car
My problem is local import tax for vehicles. For 575 kind of vehicle they add about 30-40% of the value of the vehicle.
Old Jun 19, 2024 | 02:17 PM
  #575
Paldi's Avatar
Default I fixed my driver side door wood trim crack today.
My XJL has a tiny crack under the Meridian logo, down to the bottom edge of the wood trim strip. I purchased a windshield crack repair kit and applied the liquid to the crack
It vanished! See before and after photos plus a picture of the stuff I used.
The crack
Another picture of the crack
What I bought to repair it.
After the repair. I'm happy. I'll put a little wax on it tomorrow, to make it perfect.
Old Jun 20, 2024 | 08:41 AM
  #576
clubairth1's Avatar
Community Influencer
Nice repair! Can't see it at all afterwards.
I have always had to send the panels off for refinishing.
Old Sep 14, 2024 | 03:13 PM
  #577
Stuart S's Avatar
I replaced all of the worn and missing black mushroom foot treads (bumpers) on my aftermarket floor mat protector. Pedal and footrest covers are aftermarket.
Old Jun 6, 2025 | 12:12 PM
  #578
Stuart S's Avatar
Today I installed my fourth and final illuminated sill plate. I got lucky and found a used one at a bargain price on eBay. The ad said it fit 2014-up, but I thought it would also fit my 2013 and it did. A real bargain at $39.43 plus shipping and tax.
Installation is easy, but you'll need a plastic trim tool to remove the old plate (just pry it up and off) and a rubber mallet to hammer the pins in the top of the new plate into the corresponding holes in the floor plate, which includes the wiring and socket for the power to the new sill plate. The entire job should take less than 15 minutes. Shown with my aftermarket puddle light.
P.S. What's the difference between 2010-2013 and 2014-up illuminated sill plates? Early plates are stainless steel, later ones are aluminum, which costs less but are easier to scratch.
Old Jun 6, 2025 | 02:01 PM
  #579
Meanmugga's Avatar
Good note on the steel vs aluminum plates. Never knew that.
But I just finished up my illuminated package as well. Converted 2 rear vents to fit the 2 I was missing on the center dash piece.
Old Jun 6, 2025 | 02:05 PM
  #580
Meanmugga's Avatar
Also... how long have you had those puddle lights? I'm looking for some that actually last.
