XJ ( X351 ) 2009 - 2019
Where to plug in Mirtronics
Old Mar 18, 2024 | 11:43 AM
lotusespritse's Avatar
Default Where to plug in Mirtronics
I just bought a Midtronics PSC-550S for whenever I need to do any diagnostics work in the future. Quick question, does it need to be connected directly to the positive post of the battery and a chassis ground, or can it be connected to the battery posts in the engine bay?
All the official Jaguar docs I can find with searches just vaguely say to connect it to the car.
Old Mar 18, 2024 | 12:06 PM
clubairth1's Avatar
Community Influencer
Don't know but I go straight to the source. In the trunk + on positive terminal of battery. - to where the ground strap is attached to the body of the car.
Mainly because I have measured the car using 30+ amps for hours on end when using SDD. Why so much current drain? I don't know but on my car I see large current draws.
I just assumed it's an SDD requirement?
Old Mar 18, 2024 | 02:49 PM
Thermo's Avatar
Veteran: Navy
Lotusespritse, due to the power supply being capable of up to 55 amps, I would be hard wiring it to the battery and a ground point in the trunk. That is more current than 99% of the wiring in the car can handle. So, instead of taking a chance and hooking to a circuit that could handle the power, guarantee yourself that it will handle the power. This may even be something worth considering a welder type of plug for to allow you to unplug the device when you are not using it and have a connector that is capable of handling the current. Yes, a plug like what I am talking about is an added cost, but it will make life a lot easier and will guarantee you won't have issues in the future.
Old Mar 18, 2024 | 09:37 PM
Good points. I will hook it up in the trunk.
badicedog
May 18, 2019 06:11 PM
Rogelio Serrano
Dec 2, 2016 07:11 AM
pro325
Apr 23, 2013 06:39 AM
Jerry the Jaguar
Aug 7, 2012 11:02 PM
harnack
Jan 10, 2012 08:32 AM
