XJ ( X351 ) 2009 - 2019
Will a 20x10 front wheel fit 2012?
Old Aug 7, 2024 | 05:31 PM
73TA's Avatar
Default Will a 20x10 front wheel fit 2012?
Will a 20x10 front wheel fit 2012 XJL? I found a great deal on wheels but they are 20x10 with an offset of 45MM.
Mike
Old Aug 11, 2024 | 03:30 PM
Mandrake's Avatar
Look your car up here and see if that offset falls within the acceptable range.
https://www.wheel-size.com/
Old Aug 13, 2024 | 08:22 AM
73TA's Avatar
I have been to that site. The offset would not be the problem. It would be the width of the tire (275) that might rub when the wheel is turned lock to lock.
Mike
Old Aug 14, 2024 | 07:28 PM
Mandrake's Avatar
The stock 9" wide front is within the acceptable range for a 275 and the 10" rear will take up to a 295. As for clearance, you're going to have to go in and physically measure it.
jschimmels
Jul 9, 2022 03:21 PM
Hubby528
Nov 27, 2021 03:11 PM
C-J
Apr 10, 2013 05:24 PM
LETAP007
Jan 18, 2011 01:00 PM
