XJ ( X351 ) 2009 - 2019
Window problem
Old Mar 21, 2019 | 05:50 AM
garysaunders85's Avatar
Default Window problem
I just bought a 2010 XF and I noticed when I roll the window completely down and then roll completely back up it will reach the top and then automatically go back down again. I've had to inch it up to get it to stay at the top. Is this a setting or just something broken?
Old Mar 21, 2019 | 08:30 AM
Brutal's Avatar
Make sure the seals the window rides in are clean and try lubing them with a dry silicone. Then reset the limits of the windows by holding each switch fully up for 5 seconds then drop windows and hold switch down. This resets the electrical resistance reading learned by the door modules. If neither of these works the motor is pulling too many amps and i would replace the regulator and motor assembly
Old Mar 21, 2019 | 10:46 AM
Thanks. Looks like the reset worked for me
nd4spdlsc
Nov 26, 2019 07:43 PM
Leichardti
Sep 6, 2014 04:35 PM
Jag Pilot
Jul 4, 2013 10:09 AM
mechelement
Jun 15, 2012 01:44 PM
Dec 31, 2006 02:42 PM
