XJ ( X351 ) 2009 - 2019
Window tinting....
Old Aug 4, 2021 | 09:07 AM
Na5h's Avatar
Question Window tinting....
Was thinking about adding darkening tint film to the car, but have a question for those that may know, regarding the double-paned glass windows. The XJ has double panes in the roll-down windows. I know that for a building (home, etc), that generally have double paned windows, a reflective window tint is not recommended because of the air gap between the panes heating up and leading to issues. So, knowing that, I do not intend to have the reflective kind, but the regular tinted kind which would provide some cooling when parked in the sun and also provide privacy in the rear of the car (as that would have a heavier/darker tint). With the summer heat in TN, I will be adding the darker tint if there are no detrimental issues with the windows and I am ok with the looks of the car when completed. The question is: does the normal dark tinting also heat up the gap between the panes where I could be heading into problems further down the road? (no pun intended)
T I A for your feedback.
Old Aug 4, 2021 | 10:27 AM
Thermo's Avatar
Veteran: Navy
I have had dark tint (20%) on my car for 5 years now with no issues.
Old Aug 4, 2021 | 10:56 AM
clubairth1's Avatar
Community Influencer
Automotive safety glass has no air gap. Completely different product compared to housing/building double pane glass. You won't cause any problems using a reflective tint.
Old Aug 8, 2021 | 08:37 AM
Na5h's Avatar
Thanks for the feedback!
mjlaris
Dec 2, 2023 01:56 PM
F355c5
Aug 7, 2016 10:30 AM
PD2911
Dec 21, 2014 05:24 AM
K.Westra
Aug 3, 2010 11:59 PM
XJ40ish
XJ40 ( XJ81 )
22
Jul 30, 2007 09:21 AM
