XJ ( X351 ) 2009 - 2019
x351 5.0 rough idle when off AC
Old Aug 26, 2018 | 11:31 PM
jagmt's Avatar
Default x351 5.0 rough idle when off AC
recently i noticed it idles bad when i shift to P and AC off.
i would give it a few rev and the idling usually returns normal.
this aside, can the cam phaser/ tappets/ lifters / chain tensioners caused this ? the car still has ticking noise throughout the day though it ticks less when i add the engine oil.
been to a few mechanics, all says it is not the chain noise. some say it is the tappet not getting enough oil pressure and adding oil helps (which i tried). read up a fair bit on this problem and on ford f150 forum, the possibilities extended to these parts. is there any ways to correctly diagnose the cause ?
Old Nov 4, 2018 | 03:26 PM
Darealwoody's Avatar
I’m having the exact same issue. Did you ever get the issue fixed?
Old Nov 4, 2018 | 06:34 PM
jagmt's Avatar
the AC was due to the broken intake pipe which has been rectified. Plastics do break over time in this engine.
Old Nov 4, 2018 | 06:43 PM
Can you give me a call? 8505446255 I wanna describe my issue to you
mystype04
Apr 11, 2019 08:46 AM
JaromirJaguar11
Sep 10, 2018 09:02 AM
93greenconv
Jul 27, 2014 09:04 AM
xjrwithproblems
Nov 9, 2013 02:56 PM
Ipc838
Jun 26, 2012 02:50 PM
