XJ ( X351 ) 2009 - 2019
XJ 3.0D 300PS Turbo Actuator Stuck High (Restricted Performance)
Old Jul 18, 2021 | 04:09 PM
zYx's Avatar
zYx
Exclamation XJ 3.0D 300PS Turbo Actuator Stuck High (Restricted Performance)
As I was pushing down the motorway the other day, I got the first performance issue since I bought the car 9 months ago. It's a 2016 XJ 3.0D 300PS engine with 54k miles.
I carried on driving for another 30 miles, parked the car, went shopping and when I returned to the car about 45 minutes later, the message was gone and the car performance was back to normal.
I had this happen twice more recently, turning the car off for 30-60 seconds fixes the problem...
I'm no mechanic but when I got home, I plugged SDD in and I found two DTCs: (I don't have access to Topix docs)
  • P259B-71 Turbocharger boost control position sensor B performance - Stuck High (actuator is stuck)
  • P004B-77 Turbo/supercharger boost control solenoid B - circuit range/performance (commanded position not reachable)
I'd appreciate your expert opinion and whether it's something that I can "fix" to prevent this from happening again. Can I repair the solenoid/actuator, replace it without going down the turbo route?
Also, what could be the cause of this? Not sure if related, but I normally use standard diesel, and I have recently filled my car with premium diesel on the last two visits at the garage.
Many thanks
Old Jul 18, 2021 | 04:32 PM
petrmj1's Avatar
zYx, we are missing a key clue to solving this. what exactly happened before you went shopping??? Was it just the message or was there something else?
Old Jul 18, 2021 | 04:38 PM
zYx's Avatar
zYx
Well, the performance was reduced, meaning there was no boost. Nothing else happened. I use the car daily, but for short journeys.
Old Jul 19, 2021 | 06:13 AM
petrmj1's Avatar
I would check the wastegate first. make sure it is opening and closing when it should.
Old Jul 19, 2021 | 06:37 AM
OzXFR's Avatar
zYx you should head over to the Pommy forum here: https://www.jaginfo.org//
Much more diesel action and zero diesel Jags in the US.
Old Jul 20, 2021 | 08:05 PM
gloriashield's Avatar
It may be a different case than yours.
It's most likely a second turbine problem. On the valve starts leaking, first. After some time, turbine is likely to be affected. It also affects DPF. This problem occured in most 3.0D engines Jags/LRs, in my country. JLR(in my country) has been free repairing turbines on vehicles within 5 years and 80,000 km(No extended service required). They said the turbine has improvements. Before turbine replacement(my case) :
bic_bicknell
Jul 2, 2021 04:26 PM
2859bar
Jan 6, 2021 06:06 PM
watson6505
Nov 28, 2019 12:03 PM
