XJ ( X351 ) 2009 - 2019
XJ Battery buss bar cover removal
Old Sep 26, 2017 | 08:01 AM
Jjdejd's Avatar
Default XJ Battery buss bar cover removal
Want to install a quick connect Battery Tender cable, can’t seem to get the bottom of the cover off
Attached Thumbnails XJ Battery buss bar cover removal-fefbff23-f107-4267-9aca-b861e3d9c804.jpeg
Old Sep 26, 2017 | 08:39 PM
Stuart S's Avatar
What year is your XJL and which engine?
I had no problem installing a CTEK maintainer in mine. Search for my thread.
Old Sep 26, 2017 | 10:05 PM
Jjdejd's Avatar
It’s a 2015 six cylinder
Old Sep 27, 2017 | 12:13 AM
Stuart S's Avatar
Our battery compartments may be different. I connected the positive lead of my CTEK pigtail directly to the positive terminal of the primary battery, and the negative lead to a chassis ground. See https://www.jaguarforums.com/forum/x...lation-130801/ Although the photos show alligator clips, the pigtails are now secured to those terminals with nuts.
Old Sep 27, 2017 | 07:02 AM
Jjdejd's Avatar
I assume it will charge both batteries? Although my positive connection may be under the cover in my photo. I have to check again. Thanks
Old Sep 27, 2017 | 07:36 AM
Jjdejd's Avatar
Just took another look. Our layout is the same. Your hookup will work. Thanks for the help.
