XJ XJ12 ( X305 ) 1995 - 1997
Motor Mounts ?
Old Feb 18, 2022 | 11:05 PM
  #41
watto700's Avatar
G'day Oliver,
Thanks mate, it'll be interesting how it goes and what difference it makes.
When you get your front end rebuilt it will transform how the car feels and handles, very satisfying.
Cheers,
Jeff.
Old Feb 23, 2022 | 10:45 PM
  #42
olivermarks's Avatar
Old Feb 24, 2022 | 03:52 PM
  #43
watto700's Avatar
G’day Oliver,
Thanks for those pix of the shim, I’m going to have a go a making some and see if I can sort out the steering pull problem that I have with my car.
Cheers,
Jeff.
Old Feb 24, 2022 | 05:25 PM
  #44
Forgot to measure depth, pretty sure it's 1 mm, will add this dimension soon
Old Feb 26, 2022 | 09:33 PM
  #45
2 mm thickness
Old Mar 27, 2022 | 06:53 AM
  #46
Broken_Spanners's Avatar
Hello All - I just stumbled on this thread, awesome information here - THANKS!!
Can anyone confirm if the later, cheaper, mounts will work on an earlier car?
Appreciate the help!
Jeff
Old Mar 27, 2022 | 10:48 AM
  #47
Jeff
Yes, they are identical so far as I can tell. I haven't got a hydraulic mount to compare I can measure height etc before the subframe goes back in.
It also occurred to me a tuned 6.0 in a fast road car or track car would be better served by the later mounts. I originally bought my xj12 for the engine to put in a series II coupe but decided to keep it. If I find a 95-96 xjs v12 I intend to swap the drivetrain into the coupe with these mounts if I can find them.
I'll be in England next week, going to ask around on availability.
Old Mar 27, 2022 | 02:37 PM
  #48
awesome, thank you!
Old Apr 4, 2022 | 08:23 AM
  #49
John Baker's Avatar
Thanks Oliver. I really wish I had this information before doing my motor mounts. Could have saved a lot of money and had quality (and possibly superior) mounts in my car instead. I still haven't got my alignment issues squared away. I'm to the point $$ wise on the alignment I should have just taken it to a jaguar dealership and let them do all the work.
Old Apr 4, 2022 | 08:34 AM
  #50
I'm in the UK and haven't found any of the later mounts so far, still looking around. RE the alignment can you just suspend the engine, remove the power steering line connections, loosen the v mounts enough to drop 6 inches and slip the shim in?
The only reason I found the later mounts was because they were on the car- it was a positive surprise for a change!
Old Jun 22, 2022 | 03:23 PM
  #51
2 mm thickness
Just noticed while perusing parts the shims come in 1mm, 2mm, or 3mm
Old Jun 22, 2022 | 06:35 PM
  #52
watto700's Avatar
G'day Oliver,
After you sent me the pic of the shim I was about to make some and try to slot the bolt holes so I wouldn't have to drop the suspension very far and I ran across a TSB which suggested that if the shim method, to correct steering pull, didn't work to try and bias the camber of the front suspension by rearanging the shims on the upper control arms.
I did this on one side and it seems to have fixed it.
Cheers,
Jeff.
Old Jul 20, 2022 | 02:32 AM
  #53
Cat81's Avatar
Originally Posted by Ivan Hall
I managed to use 71-74 xke v12 mounts. The mounting holes are a little closer together, and for securing it to the subframe, figure it out yourself but if you want to hear what my better idea is then I'll share.
​​​​​​​I'd be interested to know what your better idea was.
Old Jul 21, 2022 | 09:25 AM
  #54
Ivan Hall's Avatar
My grammar was bad when I wrote that. I got it to work okay though. The engine isn't perfectly where it needs to be. One method is to cut the stud off the mount and tap the nut.
Old Sep 15, 2022 | 05:34 AM
  #55
Cafcpete's Avatar
Originally Posted by SleekJag12
In stock for 746 pounds per pair at Jaguar Classic! More for locals (+VAT). We need a workaround. Especially as time marches on.
Wouldn't it be great to have new mounts... making the V12 smoother than ever, and as originally intended.
Bargain at SNG at “ONLY” £543.44 Inc VAT! Plus you might get a forum discount lol
https://www.sngbarratt.com/English/#...ds=%5B23442%5D
Old Sep 15, 2022 | 06:11 AM
  #56
Cat81's Avatar
I completed this very job a few months ago due to my engine having dropped and it being free to jump off the failed mounts whilst driving, I was able to adapt the original engine mounts from the XJ81 and using new mounts from the XJS fit the modified pair of mounts to the XJ81. The result works perfectly and looks original.
Hugemungus
Feb 3, 2022 08:25 AM
12jagmark
May 20, 2020 11:22 AM
quartetchiang
Feb 20, 2020 04:58 AM
littlehandegan
Jan 2, 2020 08:10 PM
featherboxx
Jan 21, 2014 04:20 PM
