XJ XJ12 ( X305 ) 1995 - 1997
Radiator Shroud.
Old Nov 5, 2022 | 12:00 AM
watto700's Avatar
Default Radiator Shroud.
G'day Gents,
I noticed recently that the rubber flappers at the bottom of my radiator shroud have hardened and warped with old age and heat and don't close flat against the shroud allowing some recirculation so reducing the amount of air drawn through the radiator when the car is stationary.
I intend to remove the shroud and replace the flappers, has anyone here done this to their car?
Cheers,
Jeff.
Old Nov 5, 2022 | 12:20 AM
Jim Kristeff's Avatar
I have the same issue and plan on using 3mm insertion rubber.
Old Nov 5, 2022 | 03:50 AM
Parker 7's Avatar
I found some at the salvage yard but in pulling the tabs to come out of the mounting holes the tabs break
So will have to get small screws to fasten them
Old Nov 5, 2022 | 04:39 AM
watto700's Avatar
G’day Jim and Parker,
Sounds like what I’m gunna do, use neoprene sheet and either small screws or small pop rivets to affix the flappers.
Cheers,
Jeff.
Jag4
Oct 10, 2021 10:24 AM
kenbowen
Mar 30, 2016 09:09 AM
andyXJR
Sep 29, 2015 04:29 PM
Lcgi
Oct 5, 2014 07:01 AM
chrisc923
May 21, 2014 07:04 PM
