XJ XJ12 ( X305 ) 1995 - 1997
Throttle Spindle Shaft rubber bushes
Old May 4, 2020 | 10:22 PM
yelton's Avatar
Default Throttle Spindle Shaft rubber bushes
I have noticed a little inconsistency in the tickover of my recently acquired 1994 DD6 and was reading through the Jaguar Monthly XJ40 Engineering bookazine and whilst reading the ‘XJ40 V12 Buying & Servicing’ article spotted a mention of ‘incorrect throttle adjustment’ and as I am not happy about the tickover on mine I read further and it says ‘Check also the rubber bushes on the butterfly spindle shafts’. So I did and I noticed straight away a load of play, no sign of a bush on the nearside plus what looks like the remnants of a ‘bush’ on the offside. I went to the appropriate page on the Jaguar parts website (https://parts.jaguarlandroverclassic.../brand/jaguar/) but it doesn’t show any bush, although it does show a circlip which mine hasn’t got! I’ve also checked the equivalent illustration on the XJ81 and S3 XJ12 pages which are identical to the X300 one. So, no part numbers - I don't particularly want to get into making custom bushes as I'm sure someone sells them. Any advice or comments or name of supplier/part number.
Old May 4, 2020 | 10:42 PM
Doug's Avatar
What most commonly fails, and I what I suspect you're asking for, is part number C34388, Item #24 in this illustration
https://parts.jaguarlandroverclassic...4388-bush.html
Old May 5, 2020 | 12:25 AM
SleekJag12's Avatar
Nice find Doug, Master of All Jaguar Needs!
An important little bush indeed. That's why they are 5 quid apiece and can only be had in packs of 5! It's good to have spares, right?
I need some too, I have a side with a piece of rubber hose in a supporting role. I think it's the "nearside" one.
Robert, be sure to get the linkages correct so they open equally. If not you'll get a MAP sensor code due to the mismatch. That also indicates that one bank is working harder than the other.
What is this "2004 X305" you refer to in your signature?
Old Jun 2, 2020 | 05:44 PM
yelton's Avatar
Hi Richard
oops bit of a typo in the signature - it's a 1994!! Thanks
Robert
Daim
Dec 3, 2016 11:36 PM
sogood
Jul 4, 2016 04:14 AM
Greg in France
Jul 5, 2015 04:54 AM
shl1980
Aug 14, 2012 06:04 AM
Grant Francis
Jun 9, 2012 03:45 AM
