XJ XJ12 ( X305 ) 1995 - 1997
Vibration rear axle speeds 60 and over.
Old Jan 12, 2021 | 06:44 AM
Olav's Avatar
Default Vibration rear axle speeds 60 and over.
Past weekend I did a lot of kms on the highway, cruising speed between 60mph and 75mph. Since I bought the car this was the first time to do so much highway cruising and also the first time I had my family with me. My DD6 is a Majestic so a maximum of 4 will fit.
The highways in Holland are usually of a very smooth surface which makes every vibration of the car itself noticeable. When the road surface is very gently going up and down and the car sways just gently with the road surface there is vibration on the ingoing stroke of the rear axle, not on the outgoing stroke. The vibration becomes more present when the ingoing stroke is longer (deeper) or the speed is higher. On speeds below 55mph the vibration is almost gone.
Does any of you recognise this and have a plausible diagnosis?
Thanks for your help, Olav
Old Jan 13, 2021 | 11:01 PM
xalty's Avatar
post in the 300 and 308 section, both can help you.
rear axle unoints good and lubed?
wheel bearings good?
hub pivot bearings good?
output shaft bearing good?
Gerard
Oct 18, 2019 05:06 AM
shma85
Jul 9, 2018 11:17 PM
justenough
Jul 3, 2017 03:33 AM
Freebird
Mar 24, 2015 12:40 PM
