04 vdp need help
Old Nov 29, 2020 | 07:29 PM
Pancho Deez's Avatar
Default 04 vdp need help
my jag difficult too start after sitting in the car while engine off and listening too radio for ex 20mins when i try turning it onn is hard too turn onn sometime i have too floor the pedal too start it and sometimes it starts but engine shakes only happens when i sit and listeb too the radio on the car and the car is off any help?what can cause this
Old Nov 29, 2020 | 07:41 PM
joeleerj's Avatar
Pancho, I'm in Memphis as well
Have you checked your battery Low battery voltage can cause a lot of problems wit our cars.
Old Nov 30, 2020 | 04:53 AM
yea i actually have a new battery in the car the car turns onn fine and runs good only when i sit in the car with the engine off for 20mins and try starting it does that misfire
Old Nov 30, 2020 | 07:42 AM
Blairware's Avatar
Sounds like a issue I have had with both X350's at times. The 20 minutes was tge clue. You may have a leaking fuel injector with a bit of crud or grain of dirt holding it open. It leaks down and fills a cylinder with fuel, and restarts are super difficult. Leave it longer and it evaps or runs into crankcase, short is okay too..this is why flooring it helps.
Try a few cans of good fuel injector cleaner at a strong concentration (no more than 10 gallons of gas). If that fails, there's Seafoam upper engine cleaner and lube spray, but be ready to fill the neighborhood with smoke after the heat soak, and you will probably foul the plugs in the process. Change your oil after using that stuff. I had 2 day old oil go jet black (cheap stuff used for sacrificial purposes.)
Good luck!
Old Nov 30, 2020 | 08:41 AM
Blairware's Avatar
One other thought: What are you listening to on the radio? Try switching to Stevie Ray Vaughn. Engines respond to that.
Old Nov 30, 2020 | 09:27 AM
Good luck!
could be because when i put the check engine ligth it marks that my 02 sensors are misfiring in bank 1
Old Dec 1, 2020 | 12:03 PM
joeleerj's Avatar
Where are you in Memphis? Maybe we can get together and I can help you solve this problem. I have a Mongoose cable and SDD also.
paulkingnz
Nov 1, 2020 04:20 PM
kenatofc
Aug 31, 2019 02:28 PM
bjg625
Nov 27, 2014 02:07 PM
