'04 xj8
Old Feb 6, 2013 | 07:39 AM
acbsfb's Avatar
Default '04 xj8
Anyone know how to remove B Pillar? Material got wet and shrank, need to replace.
Old Feb 6, 2013 | 11:08 AM
Fraser Mitchell's Avatar
I assume you mean the internal trim. I'll have a look on my JTIS disc tonight to see if there is a procedure for this in it.
Old Feb 8, 2013 | 07:45 AM
acbsfb's Avatar
Any luck? I bought one of those discs once but wouldn't run (Needed XP, haven't had that for a long time, couldn't find anything current)
Old Feb 8, 2013 | 02:02 PM
Sorry, something came up. I'll have a look now
Old Feb 8, 2013 | 02:27 PM
OK, its here on my PC upstairs running XP !
Like all these trim things, its a PITA !. First off, you take off the Scuff plate trim panel, a black plastic panel on the bottom of the door shut, (not the chome piece with 'Jaguar' on it). From the JTIS pic, one lifts it up from the front.
Then you need to remove the lower B-post trim - (1) detach front and rear weather strip - pic shows a pull, there is no text (2) pull off the lower trim panel
Then remove the upper trim - (1) as per lower detach front and rear weather strip. (2) Remove seat belt cover on front seat (2) unbolt seat belt (3) Remove upper trim. You feed seat belt through its slot, then tie it up to to something.
Sorry no pics but I can't copy/paste off it
Old Feb 8, 2013 | 05:33 PM
34by151's Avatar
Fraser, download windows xp mode from microsoft
Download Windows XP Mode
This is free virtual machine for Win7 on.
Once you install add your XP apps.
You can now turn on seamless mode and add the icons from XP to your desktop
In seamless mode you wont see XP at all
34by151
magmedia
Oct 8, 2015 03:28 PM
freddieg
Oct 6, 2015 11:23 AM
mat32essex
Oct 3, 2015 04:12 PM
kingdom worker
Oct 2, 2015 05:43 AM
donald ebanks
Sep 30, 2015 07:08 PM
