04 XJ8 Bluetooh "Handset in use" Message
Old Jun 22, 2013 | 09:30 PM
Yaoi-Wiccan's Avatar
Default 04 XJ8 Bluetooh "Handset in use" Message
Hi, I just bought a 2004 XJ8 and the dealer told me it had the bluetooth mode in it. But every time I press the phone button I get the message saying the handset is in use. Im not sure if he was wrong and I don't have it or if Im doing something wrong?
Old Jun 23, 2013 | 02:12 AM
veffremov's Avatar
Congrats on your purchase. Go back to the dealer and ask them to demonstrate how to use the alleged Bluetooth module, if they can't politely hint that thy should maybe fix it.
"handset in use" happens to me on rare occasion if the BT/Phone module gets confused, it usually fixes itself. If it happens to you all the time could be an indication of a bigger issue.
veffremov's Avatar
Old Jun 23, 2013 | 09:56 PM
vacmail's Avatar
Congrats on your purchase also. My 04 XJ8 did not come with the phone i found the complete kit on e-bay and install it works great. One day I got in the car and the "handset in use" came up I was worry that I wasted a lot of cash. I turn the car off and turn it back on and it reset and started working. I would take it back and let the dealer check it out. It did happen again, what I did this time was unplug the BT/Phone module unit clean the connect and plug it back in and have not had anymore problems. The BT/Phone module unit is also the easy part of the whole set-up to get to, just remove the cover to the rear vent(it just pops out) and it's sitting right there
Good Luck,
Old Jun 24, 2013 | 08:35 AM
I took the back vent off and did see the red harness with the cable plugged into it. I unplugged it and plugged it back in and still get the same message.
Old Jun 24, 2013 | 09:57 AM
I also unplugged the battery and let it sit for awhile but when I plugged it back in it still has the same message.
Old Jun 25, 2013 | 12:31 PM
Does anyone have an idea why it might not be working?
Old Jun 26, 2013 | 08:18 AM
greg-05vdp's Avatar
I have the same issue and have tried the same things as well. Disconnected the battery, disconnected/reconnected the BTUM cable in the rear vent to no avail. Gave up for now, but I'll try tackling sometime later this year. If you do keep digging and get it to work, let me know (as will I).
Old Jun 26, 2013 | 11:04 AM
The labels on the cables say phone line and the red dock has the plug in. I just don't understand why it will not work.
Old Jun 26, 2013 | 08:59 PM
The cable says "Phone ANT (FED) Phone only. Phone Hang Up Cup. Interesting the cable date says 030206 for a 04 car?
bdboyle
Sep 16, 2019 05:58 PM
magmedia
Aug 15, 2019 08:54 PM
jagxk2008
Feb 4, 2016 09:53 AM
donald ebanks
Sep 30, 2015 07:08 PM
zdrapec
Sep 25, 2015 05:49 AM
