04 XJ8 Motor Mount Repl.
Old Jan 15, 2023 | 08:53 PM
Tony_Likes_Going_Fast_XJ8's Avatar
Default 04 XJ8 Motor Mount Repl.
So a motor mount completely collapsed on me the other day going over a pot hole too fast. (picture below)
I was wondering if anyone knew whats the most convenient way to replace this mount. & only by doing so with just jack(s) & jack stands. also probably going to replace the second mount too that for some reason has what looks like to be a strap on it?..
(oh and also gonna have to replace the serpetine belt because after the mount collapse now the A/C compressor pulley is against the subframe)
Btw I have a 2004 Jaguar XJ8 4.2L NA.
thank you.
(1st picture is snapped mount)
(2nd picture is questionable mount and why the strap?)
(3rd picture is engine visibly tilted)
Old Jan 16, 2023 | 03:11 AM
FreeWifi's Avatar
The strap is part of the motor mount. The workshop manual details replacing them. Some people lift the engine from under the car as in this video around 6:48 mark.
or if you don't feel comfortable jacking up the engine you could get the harbor freight support bar https://www.harborfreight.com/1000-l...bar-96524.html
Search from forum https://www.jaguarforums.com/forum/x...cement-223314/
Old Jan 16, 2023 | 04:22 PM
Wingrider's Avatar
Replacing the alternators in both of mine
Have removed the passenger motor mount both ways.
Liked the jack & wood block way better myself.
Old Jan 18, 2023 | 06:53 PM
JoeDredd's Avatar
I did the jack and wood block on my alternator swap as well. It works ok but you will be surprised at how high you have to go to get the mount back in, or was it to get the clearance to get the alternator out?
Old Feb 25, 2023 | 05:18 AM
Petz's Avatar
As well changed while the alternator hsd to come out for a refurb.
same procedure for the Diesel engine
Nedoerr
Nov 22, 2022 08:01 AM
Badbenz94
Jun 11, 2014 10:34 AM
plums
Nov 23, 2012 06:31 AM
plums
Nov 23, 2012 01:33 AM
martin fothergill
Mar 19, 2010 09:13 PM
