06 XJR got a little too hungry and ate the SC rotors
Old Apr 10, 2024 | 10:12 AM
Thermite's Avatar
Originally Posted by Thomas-S.
I would rather say that the round black objects are the valves, you can see the valve seat of the bottom one.
In any case, OUCH is the correct term. Even if the original damage is "only" the cylinder head, I fear that metal particles have damaged the cylinder itself.
Best regards,
Thomas
One go, (different race of maker) it had spared the bores, only 'coz it couldn't RUN.. but also cracked several pistons and bent at least one connecting rod. Busted valve heads are dam' hard to compress!
Learn & live...
Old Apr 10, 2024 | 03:38 PM
Wingrider's Avatar
You are right, valves they are.
Old May 7, 2024 | 09:23 AM
bagpype's Avatar
Originally Posted by JagsteRJX
Taking a quick look for used engines online I did see an 09 XF 4.2 SC with 80k miles for $3k.
Will the XF engine work in the 06 XJR?
Daniel Macdonald
Feb 23, 2021 09:01 PM
Steve W
May 23, 2018 09:43 PM
damianpenney
Feb 9, 2011 04:51 PM
bigcat
Jan 26, 2010 12:50 PM
LUXCAR
Oct 29, 2008 12:05 PM
