2009 xf engine in 2006 XJR
Old May 7, 2024 | 06:52 AM
bagpype's Avatar
Default 2009 xf engine in 2006 XJR
Does anyone know if a supercharged engine from a 2009 XF will drop into a 2006 XJR? I am having a hell of a time finding an engine for my 06 XJR but there is an abundance of 2009 xf engines locally.
Old May 7, 2024 | 07:00 AM
abonano's Avatar
Short answer - no!
Old May 7, 2024 | 07:02 AM
bagpype's Avatar
Originally Posted by abonano
Short answer - no!
What is the major difference?
Old May 7, 2024 | 07:06 AM
abonano's Avatar
Basically the PCM. If the PCM from the XF can connect (directly) into your existing harness on the 06 XJR, then you may be in luck.
Old May 7, 2024 | 01:42 PM
xalty's Avatar
yes but swap the blower inlet duct, xf has a bigger fitting for the brake booster pipe
alternator needs to come from the xj
Old May 7, 2024 | 03:11 PM
bagpype's Avatar
I have all of that from the XJR. Have you done this swap before?
Old May 7, 2024 | 03:35 PM
xalty's Avatar
i have both engines side by side installed in the cars. 100% the same except for the harness and the blower inlet
jagxkrtoofast
Mar 4, 2021 12:35 PM
rwolak
Jun 2, 2019 02:38 PM
Dfern12
Apr 19, 2017 08:35 AM
EyeDoc
Oct 28, 2013 01:16 PM
