2004 Amber check engine telltale
8 yrs of perfection but, last week went on a trip, check engine light came on amber with reduced performance note. Car was running fine. When got around to checking things out, I found the air intake tube loose at connection to throttle body. Tightened it, all well except the light won't go out even after a battery disconnect. Do i need an OBD2 tool to reset it?
I think certain check engine/MIL/CELs will go out after a defined number of drive cycles
