2004 xj8 460 532 bbf build
Old Sep 2, 2017 | 04:37 PM
  #41
04 xj8's Avatar
engine swaps do not get any easier than this, every thing was really just bolt on except driveshaft which came out great! it starts and runs now, i have to figure out cooling system and details, exhaust will work with this motor so it'll be quiet as ever till i open my electric dumps. heres a short video! https://www.youtube.com/watch?v=H8Vk...ature=youtu.be
Old Sep 2, 2017 | 04:47 PM
  #42
04 xj8's Avatar
oh yea and heres my driveshaft, just a turbo 400 slip yoke inside a factory jaguar shaft, it fits well but had to build a shim to center the shaft so its all true, easy as can be but id imagine it will need balanced in the future.
Old Sep 2, 2017 | 06:51 PM
  #43
04 xj8's Avatar
alright, the jaguar radiator will work but i need a electric external water pump and block off kit look at where that factory upper rad hose comes out to lol.
Old Sep 2, 2017 | 07:10 PM
  #44
04 xj8's Avatar
alright problem solved, this is a long snout pump and it barely clears with some fudging getting the rad to move foward, ill get a shorty pump and have almost an inch clearance, so now ive got a radiator
Old Sep 3, 2017 | 09:42 PM
  #45
04 xj8's Avatar
its tight but it seems to work
waiting on my alternator bracket and gm 1 wire alt, i want it clean and simple. also waiting on after market cooling fans for the front of the radiator, the factory fans will not fit.sadly
all the wires you will need with this drivetrain, i have to tidy it all up better than this though.
this carbed fuel pump works great but i had to take out the fuel pump in the tank and run a pipe where the pump goes, also had to take out the check valve so it would pull though, simple enough.
Old Sep 3, 2017 | 09:45 PM
  #46
04 xj8's Avatar
factory shifter has no chance of working, it will have to have a after market mounted in place of where the original one goes.
Old Sep 3, 2017 | 09:47 PM
  #47
04 xj8's Avatar
works for now till i can find proper clamps to hold the engine mount bar down to the cradle, its actually fairly secure but dosnt look right.
Old Sep 3, 2017 | 09:50 PM
  #48
04 xj8's Avatar
gauges show everything wrong, but i wonder if theres a way to make the dummy lights work with the motor, abs has no chance of working but thats not needed lol, fuel gauge works great, im curious to try the tac with this distributor.
Old Sep 16, 2017 | 03:05 PM
  #49
04 xj8's Avatar
Default thar it be, gotta button up a few things and figure why its having trouble shifting
https://www.youtube.com/watch?v=J--j...ature=youtu.be
Old Sep 24, 2017 | 05:21 PM
  #50
04 xj8's Avatar
of all the things that should have blown my brand new Hughes turbo 400 stops shiting, lucky its still under warranty, trans took 45 minutes to pull, lol so much room to access the bolts. should have it up and running again in a few weeks.
Old Nov 5, 2017 | 06:02 PM
  #51
04 xj8's Avatar
completed engine bay except valve covers, almost looks factory lol
Old Nov 5, 2017 | 06:08 PM
  #52
04 xj8's Avatar
and now for the interior gauges. hope to locate a gps speedometer same size as factory speedo and a nice after market tac, it will be nice to eliminate these warning lights, electric exhaust dumps are due in next week, it will run into the factory exhaust and be crazy quiet. got my street strip drag radials on it, 10 hard launches and so far this rear end is holding up fine. these nitto nt05s hook really well, 650 ft lbs feels like it would snap my neck off if it wasnt planted into the head rest. lol
Old Nov 9, 2017 | 09:51 PM
  #53
04 xj8's Avatar
good looking 20's i should have gone with a 275 though. these nittos hold this hp quite well, surprised rear end hasn't given out, still cant give it full throttle on launch but almost on a hot day when these grip, oh and by the way this thing is crazy high geared, at 80 its only reving 1800 rpm lol, this 3000 stall converter sure helps get that power to the ground.
Old Jan 18, 2018 | 09:57 PM
  #54
04 xj8's Avatar
Default been awhile since i have posted
2000 miles now, this rear end will not die, lol raced a 1000 hp ctsv and of course didnt win but got him on takeoff for aways. i got my electric exhaust dumps installed and summit cooling fan controller, kicks on at 195 and off at 175, surprised this dosnt overheat. with the dumps closed it sounds almost stock except a very quiet lope at idle. the factory exhaust must not be very restrictive, i see no power decrease until 3500 rpm with the dumps closed, its very quiet until the dumps open.
Old Jul 16, 2024 | 09:54 PM
  #55
Jay1977's Avatar
Default Oil pan
Originally Posted by 04 xj8
I cant believe how well this 460 fits, its like ford designed it to fit,
i bought the car with a blown head gasket because the lady ran it out of coolant 1100 bucks so yay!
this 532 made 610 hp 650 ft lbs to the crank, 7800 dollar engine build.
i thought i would share this, look at all the room, the one pic the engine is lying in there unbolted, the others its bolted up with jaguar mounts.
i can fit two bolts in those mounts if I oblong one hole an 8th inch.
block hugger headers have tons of room and even fit the factory exahust, no mods.
ford slip yoke driveshaft should cut and slide onto the jag shaft i hope.
i just started this build so bear with me for month or so as i have a race c6 on its way, hope it fits.
what type of oil pan the one used in mustangs with the double hump or the ones used in trucks with the rear sump
