2005 VDP headlight problem
Old Jan 16, 2023 | 12:37 PM
Terrific's Avatar
Default 2005 VDP headlight problem
My left headlght is out sometlmes. On startup it will usually blink ( on auto ln garage) Seems to settle down after on for while. I've dismissed it as auto leveling, actually I don't even know if it has auto leveling. Anyway when pulling into a resturant the other night I was told the light was out. When returning home it was working. The blinking has been ongoing for some time. Grounds have been replaced. Any help appreciated.
Old Jan 16, 2023 | 03:55 PM
meirion1's Avatar
Scan for codes first.
There have been some faults reported about faults in the stalks.
Apparently the wires are really crammed in there and it is easy to replace
since it is a replaceable cassette but scan first.
Old Jan 17, 2023 | 08:34 PM
Terrific's Avatar
I just tried scanning with my Icarsoft but cant get any communication with lighting module. Now what. lights worked fine today.
Old Jan 17, 2023 | 08:51 PM
Luke2004xjr's Avatar
Sounds like it could be the Ballast, It is attached on the bottom of the headlight unit.
Old Jan 18, 2023 | 06:39 PM
JoeDredd's Avatar
Swap the bulbs around and see if the fault moves with the bulb or stays with the headlight. Its a bit of a squash taking the bulbs out but it can be done. The ballast on the otherhand is headlight out.
Old Jan 18, 2023 | 06:45 PM
Aarcuda's Avatar
Do you have HID lights? If so the ballast need to be replaced
pbcs004
Nov 22, 2024 01:39 PM
Estam
Jan 22, 2023 02:56 PM
stanigu
Sep 28, 2013 09:03 AM
garf90
Oct 13, 2009 01:38 AM
