2005 X350 XJ8L headlights condensation
Old Feb 13, 2024 | 09:42 PM
ShoshXJ8L05's Avatar
Default 2005 X350 XJ8L headlights condensation
Is there a non removal remedy for this issue?
Old Feb 13, 2024 | 11:17 PM
TommyBoah's Avatar
I'm pretty certain the main cause is the adhesive between the lens and housing has gave up, so the only way to fix it is to have the headlight apart unfortunately.
I also have the same issue, although it only occurs rarely so I don't really bother with it much.
- Khoa
Old Feb 14, 2024 | 03:51 AM
Petz's Avatar
Condensation can be removed by opening the lid and left open while lights are switched on blow cold air in with a hairdryer
I removed my gasket ,gently soak cleaned with a tooth brush in warm soapy water .
I put a thin stripe of silicone into the guide then put the dry gasket back in it. Not having any issues since
Cooljag
Jul 17, 2023 06:32 PM
Rambo12
Mar 31, 2023 08:25 PM
Estam
Jan 22, 2023 02:56 PM
MaxTorq
Jan 7, 2022 11:10 PM
