2005 XJ8 Headlight issues
Old Dec 27, 2019 | 02:23 PM
V. Great's Avatar
Default 2005 XJ8 Headlight issues
Hello! I've just recently acquired a 2005 XJ8 and my issue is the driver's side (left) headlight doesn't work. I've bought new bulbs, checking them on both sides and the bulbs are good. Checked the engine compartment fuse box and found that fuse #9 Left hand dipped beam has no power. The fuse isn't blown, and I've checked it with a multimeter... Nothing..
Any help would be very much appreciated!!
Old Dec 28, 2019 | 05:23 AM
JX350's Avatar
Hi. I had problems with my left headlight and indicator in the headlight assembly. Mine was the ground point just behind the headlight assembly. Check to see if it's broken or needs a clean.
Old Dec 28, 2019 | 09:38 AM
Rickkk's Avatar
I have a 2005 Jaguar XJ8L. I'm not sure which of the two types of low beam headlight bulbs that your car uses but my Jaguar uses a Wagner BP1255/H7 which is a 55 watt bulb. Hope that helps.
momo
16
Sep 15, 2025 08:27 AM
terragnosis
Jun 30, 2019 12:20 PM
David Clews
Diesel variants - All models
Feb 13, 2019 01:00 AM
DJ-Roy
Jul 15, 2018 03:54 PM
MikeB6.6
Jan 11, 2010 07:34 AM
