2005 XJ8VP Wiring...and ??????????
Old Dec 30, 2021 | 02:51 PM
benzjag's Avatar
Default 2005 XJ8VP Wiring...and ??????????
My 05 XJ8 ran terribly this week upon startup. Raising the bonnet, I found a damn f...king squirrel had cut most of the wires that run in the bundle on the right side of the engine (looking from front of engine) above the injectors. MY mistake was I had not put the engine cover back on (even though it was only the day before).
I soldered the wires back together with heat shrink tubing being extremely careful to match the colors perfectly. The car now starts and idles perfectly, but will not accelerate above 5 miles mph with the pedal to the floor. I have the following:
1. Display says:
A. Restricted Performance
B. Parking Brake Fault
C. Fault Communicating with Vehicle ECU
D. Engine System Fault
E. DSC Not Available
2. CHECK Engine Light
3. Traction control light on (does not extinguish
when pressing the button near the gear shifter).
I tried to use my isoft Jaguar Scanner, but it says diagnostic not available;therefore, I couldn't get in the engine management to reset the check engine light and to read codes.
The car was running perfectly UNTIL the ******* chewed the wiring.
ANY help will be most appreciated!
Richard
Old Dec 30, 2021 | 03:58 PM
meirion1's Avatar
Have you tried a hard reset?
Are you sure that the bu..er has not attacked wiring elsewhere?
Old Dec 31, 2021 | 11:21 AM
JagV8's Avatar
Battery somewhat flat?
Johnny2Jags
Sep 20, 2021 09:23 AM
Vincentbrough
Sep 28, 2014 02:44 PM
fourbyfourbyfar
Sep 18, 2013 04:31 AM
adinashena
16
Feb 12, 2013 12:08 PM
abnas2
Oct 10, 2012 05:20 AM
