2006 Vanden Plas satellite radio
Old Jan 9, 2019 | 10:14 PM
Peeam's Avatar
Default 2006 Vanden Plas satellite radio
The satellite radio, which as I understand was an aftermarket install by Jag dealers, has stopped working. It comes on but never moves to the next screen showing the channels. It is either not receiving any signal or has just gone bad. I contacted Sirius XM and they sent me a replacement radio which is not identical to the one installed in the car. I am unable to find an installer who will install the new one in the same space. I have borrowed from the another post a picture of the original radio. Can some one tell me if I can still find the original radio for a straight swap ? Any instructions on installing the replacement one will be great. I searched the forum for installation manual for accessories but did not find one. Thanks.
PeeAM
Old Jun 26, 2019 | 09:09 AM
XJJohnF's Avatar
Hello. I also have a 2006 VDP with this same satellite radio installed. I had exactly the same problem some time ago. I took it to a local automotive audio shop that had done work for me before on another vehicle. They immediately identified the problem as the antenna for the satellite radio. They replaced the antenna and it has worked perfectly since then. Total cost was about $70 for parts and labor. The local Jaguar dealer had no clue as to what was going on!
Old Jun 27, 2019 | 02:28 PM
Peeam's Avatar
Default Thanks
Sounds promising. Will get the antenna looked at. Thanks.
Originally Posted by XJJohnF
Hello. I also have a 2006 VDP with this same satellite radio installed. I had exactly the same problem some time ago. I took fit to a local automotive audio shop that had done work for me before on another vehicle. They immediately identified the problem as the antenna for the satellite radio. They replaced the antenna and it has worked perfectly since then. Total cost was about $70 for parts and labor. The local Jaguar dealer had no clue as to what was going on!
GrafShutka
Sep 18, 2017 09:13 AM
Road_King
Mar 15, 2014 09:36 AM
BrownRobin
Dec 22, 2010 08:23 AM
GrafShutka
Dec 15, 2009 03:05 AM
