2006 XJ SV8 Code issues - help needed
Old Jun 10, 2017 | 11:21 PM
Riv468's Avatar
Default 2006 XJ SV8 Code issues - help needed
hi there,
so I am new on this site and have joined in the hopes that someone will be able to help me with the issues I continue to have with my 2006 XJ SV8 since doing changes to the engine, exhaust, and remapping of ECM.
So to date I have added a K&N air filter, a 1.5 times pulley to the supercharger, have deleted cats and added bungs as per paramount, then I have had them write me a program for the car also. The exhaust is quicksilver performance and has been noted to paramount when requesting the remapping work.
I have since also changed the transmission fluid, filter and electrical plug sleeve, then changed all 4 O2 sensors at once which is when the issues really began to appear.
I have attached a photo of the codes I continue to get continually....any help would be great!
Old Jun 11, 2017 | 05:59 AM
paydase's Avatar
Seems to me that if you delete cats you may have all sorts of codes triggered by the exhaust sensors.
But specialists will better help you
Old Jun 11, 2017 | 09:11 AM
JagV8's Avatar
The changes and software are incompatible, clearly. I suppose you gt tweaked software or revert some changes.
