2008 XJ s/w update in engineering menu without disc and black screen/50 51 error
Old Oct 3, 2023 | 08:56 PM
mcpflrb's Avatar
Default 2008 XJ s/w update in engineering menu without disc and black screen/50 51 error
I was messing around in the navigation engineering menu where you hold telephone and menu buttons down and enter "1971" to access. I selected s/w update, confirmed and now my nav screen is black and the climate control LCD displays "50/51". I know there is nothing wrong with the audio unit itself because I put it in this mode via the s/w update button. Does anyone know a way to revert it back to normal operation without having to buy a nav DVD update or otherwise without having to spend any money? I found other threads on the subject but no definitive answer for when this results from the s/w update process.
Old Oct 4, 2023 | 05:12 PM
JagV8's Avatar
Look for threads on 50/51 or loading.kwi
You need a sat nav disc with the firmware to load into the module or else change the module.
Old Oct 13, 2023 | 01:58 PM
Eag's Avatar
Eag
Default Same problem!
I did the same thing.
did you figure out a solution ?
Old Oct 14, 2023 | 01:45 AM
JagV8's Avatar
Post #2
08xjjonas
Nov 4, 2019 02:43 PM
norb
Jun 15, 2019 09:36 AM
jjkurzbuch
Oct 29, 2015 04:44 PM
imsims
Nov 23, 2013 07:17 AM
