2009 4.2L sensors and vacuum lines
Old Jun 18, 2021 | 08:55 PM
RFG's Avatar
RFG
Default 2009 4.2L sensors and vacuum lines
Need help replacing small emission vacuum lines (brittle and broken)on top of XJ VandenPLas, 4.2L normal aspirated V8. Pictures attached:
line comes out of air intake, then immediately splits to 2, then appears to have two attachments, one is a T, one just a connecter. Appears to have 3 broken lines downstream, maybe all related. "check engine" light on due to emission sensor. How important are these lines? Can one just replace the lines with new vacuum tubing? If so, not sure of the proper attachment points (diagram would be useful).
Thank you,
RFG
File Type: zip
Old Jun 19, 2021 | 04:29 AM
EsRay's Avatar
On my 2005 XJ8L 4.2 V8 that vacuum line goes from the Fuel Rail Pressure Sensor to the inlet? It provides the FRPS with a vacuum? I think all you need is a non-collapsible pipe from the FRPS to the 'spigot' sticking out of your inlet?
Old Jun 19, 2021 | 07:10 AM
RFG's Avatar
RFG
EsRay
Thank you,
RFG
Old Jun 19, 2021 | 11:01 AM
RFG's Avatar
RFG
I had some problem with pictures so here goes again on the 2009 4.2L N/A.
Thank you, RFG
Chris Bonner
Sep 12, 2019 04:00 AM
Oscuridad
Jul 20, 2017 08:32 PM
ejjbee
Jan 24, 2017 01:24 PM
Simprof
Jan 25, 2012 09:54 PM
