2009 VDP Bluetooth and audio
Old Nov 20, 2018 | 04:17 PM
Peterinio's Avatar
Default 2009 VDP Bluetooth and audio
I am most likely, not the first, or probably the last person to inquire about the bluetooth and audio limitations associated with these models. Mine is a 2009 VDP with the CD stacker in the trunk. Apparently, there is something that can be done but I am yet to narrow done on anything specific. I don't mind rewiring a few things or changing a harness but not quite as complicated as the Jagdroid, and certainly more than a FM modulator.
Any thoughts?
Peter
Old Nov 20, 2018 | 08:32 PM
Datsports's Avatar
my recommendation would be to apply step one of the jagdroid set up . (add a 3.5mm aux in) to the head unit .
then you can use a jabees IS901headphone BT unit .
https://www.ebay.com/itm/Jabees-IS90...NwvA:rk:3:pf:0
or a BTI-028 BT unit to stream music .
https://www.ebay.com/itm/Excelvan-2-...lB9:rk:21:pf:0
also you can then plug strait in to your phone/device .
Old Nov 20, 2018 | 09:13 PM
Peterinio's Avatar
That sounds simple enough. Thanks for the idea.
jfire
Apr 29, 2019 02:12 PM
Kchalsey
Jul 28, 2015 02:15 PM
nalleyjagparts
VENDOR 'For Sale' Classifieds
Jun 21, 2011 03:54 PM
rothe
Dec 6, 2010 07:55 PM
rothe
Audio/Visual Electronics
Dec 5, 2010 03:38 PM
