2011 XJL
Old Nov 23, 2019 | 12:43 PM
Lorraine's Avatar
Default 2011 XJL
my 2011 XJL has a warning too low after having a flat. I repair the flat but the warning vehicle is still on. I did a scan and the only code that comes up is PO106. The car does look a little low, any suggestions?
Old Nov 23, 2019 | 03:52 PM
Fraser Mitchell's Avatar
Code P0106 is engine related so has nothing to do with your suspension problem. It might be worth taking the car to a main agent to have the vehicle height calibrated. Does your code reader read all the Jaguar codes, as some don't ?
Old Nov 23, 2019 | 04:08 PM
NBCat's Avatar
+1 on DTC P0106 having nothing to do with a suspension issue.
What is the battery voltage across the terminals with the ignition in the OFF position when measure with a voltmeter?
Old Nov 24, 2019 | 10:14 AM
JagV8's Avatar
If it really does have P0106 that's quite serious, but indeed nothing to do with suspension.
Old Nov 24, 2019 | 07:00 PM
Lorraine's Avatar
Thanks for your response. My XJ low vehicle warning only comes on within the first 20-60 seconds while moving. Strangely, when I first start up no warning. I have already changed the MAP sensor and the code PO106 comes on for a while and then it goes off. But it rides and runs great other than the recent problem Low vehicle. I didn't know that you can have the car height calibrated. Where can I get that done?
Old Nov 25, 2019 | 04:17 AM
Jaguar dealers have the software to do this, and it is a reasonably straightforward process. I would think less than one hour to carry out.
Are you sure your car is an X350 ? I would have thought that a 2011 would be an X351, the later model from 2009, that only has air springs on the rear.
Old Nov 29, 2019 | 11:19 AM
Lorraine's Avatar
Thanks, I will take it to the dealer after Thanksgiving Holiday.
Old Dec 3, 2019 | 01:59 PM
Lorraine's Avatar
Is there a youtube on changing the spark plugs for my car 2011 Jaguar XJ 5.0?
Old Dec 3, 2019 | 02:24 PM
NBCat's Avatar
The spark plugs are to be replaced at 100 thousand miles. How many miles are currently on the vehicle?
Here is a link to a thread discussing changing the spark plugs on an XF (X250) 5.0 litre car:
https://www.jaguarforums.com/forum/x...change-145292/
Read through it and decide if it's something you want to attempt.
Old Dec 4, 2019 | 04:30 AM
Partick the Cat's Avatar
You really would do better asking in the right sub-forum for your model, which is https://www.jaguarforums.com/forum/xj-x351-53/
This sub-forum is for the XJ X350/358 model which finished in 2009.
Golfing8tr
May 8, 2020 05:52 PM
BlueX
Jul 20, 2017 01:48 PM
sonicd0012
Dec 7, 2012 11:29 AM
