4.2 Engine Knock when cold / idle
Old Sep 16, 2009 | 07:32 AM
Clifsmith's Avatar
Default 4.2 Engine Knock when cold / idle
I have xj8 4.2 (85k miles) and when I first start it (when the engine is completely cold), it has a knock sound. Just like someone knocking on the door. The sound is really louder from underneath. If I rev it up, it goes away and once the engine warms, it goes completely away.
Is this a bad connecting rod bearing? That is what is sounds like. Why would it stop doing it once it is warm? What else could it be?
Old Sep 17, 2009 | 07:04 AM
Clifsmith's Avatar
Solved my own problem accidently. I had just done an oil change and put a Fram oil filter. Then I read that Fram filters are the worst, so I switched it out to a NAPA Gold Filter (Wix). Guess what, no more cold knock. I guess it had something to do with that filter and the oil pressure at startup and cold run.
Old Sep 17, 2009 | 10:41 AM
H20boy's Avatar
Very interesting...
Old Sep 17, 2009 | 10:53 AM
wazari's Avatar
Sounds like a faulty drain back valve or lack of one in the filter.
SD96XJ6L
Jan 12, 2022 04:30 AM
jehart49
Sep 12, 2015 05:36 PM
brgjag
General Tech Help
17
Sep 9, 2015 07:34 AM
KarimPA
Sep 3, 2015 07:32 PM
Bowman
Sep 3, 2015 03:17 PM
