ABS electrical problems
Does anyone have an ABS unit sitting around that they could take some resistance measurement from? I am sure mine has problems with the CAN bus. I sent it away to have it repaired however they indicated there was nothing wrong with the way it functioned. Since the function works, even with CAN bus problems, I think they are missing my problem area. I do not have a "good one" to test against so cannot prove to myself that mine is a problem!If so then resistances for following pins. Pin 1 is at top of unit next to aluminum body adjacent to where the brake lines go in. Pin 16 is the bottom one on the same side next to the aluminum body.
Thanks to anyone that can help.
Edward.
Resistances:
Pin 16 to pin 15
Pin 16 to pin 14
Pin 16 to pin 12
Pin 16 to pin 11
Pin 11 to pin 12
Pin 11 to pin 14
Pin 11 to pin 15
Thanks to anyone that can help.Edward.
Xag
Jul 13, 2022 02:42 PM
jaguarlady03
Jan 18, 2013 11:28 AM
