ABS fault / DSC not available issues
Old May 3, 2016 | 08:13 PM
javigo1971's Avatar
Default ABS fault / DSC not available issues
Hi Jager's,.,.,.\
need some help with the link to the ABS harness connector ....to check those famous pins .....i can not be able to get the codes off ,,,i all ready checked grounds and battery juice,,,,any help will be appreciate././.
Old May 5, 2016 | 01:52 PM
trosty's Avatar
Have you actually checked the ABS sensors attached to the wheels? They are held in with a flimsy plastic clip and fall out very easily. Takes about 1 minute to check all 4 sensors.
I had a DSC/ABS fault exactly like you describe and a loose sensor was the culprit.
If those are ok, I would get the Crank Amps on your battery checked.
Old May 8, 2016 | 01:16 PM
javigo1971's Avatar
Thumbs up purge valve
Hey trosty thanks for your reply......i have one more question do u know where the purge valve is located ? i also have the small leak code..thanks a lot..
Old May 8, 2016 | 03:28 PM
trosty's Avatar
The purge valve for the fuel rail? If so you will find it in the 3rd picture, a small blue (in my car anyway) valve cap, and its under there.
https://www.jaguarforums.com/forum/x...ge-how-119351/
coug66
16
May 28, 2016 06:35 PM
innzane
Apr 3, 2016 08:43 PM
tripstar76
Mar 31, 2016 11:26 AM
hub61
Mar 26, 2016 11:20 AM
hub61
UK & Eire
Mar 26, 2016 11:08 AM
