ABS Fault - error codes - NSR wheel sensor - C1236 and C1143
Old Apr 10, 2019 | 01:53 PM
buttpt's Avatar
Default ABS Fault - error codes - NSR wheel sensor - C1236 and C1143
From the above Error codes I have been provided from the car's computer, can someone let me know
what part(s) I need to order to solve the ABS fault? From my XJ6 3.0 Litre , 2004 model X350 chassis
Were NSR= Near Side Rear
Some good news is that the the rear sensors cost a lot less than the front ones.
Thank you Fellow members
Old Apr 10, 2019 | 05:53 PM
meirion1's Avatar
Would that be Bushey Herts?
https://www.ebay.com.au/itm/JAGUAR-S...-/251255771616
Old Apr 11, 2019 | 04:57 PM
buttpt's Avatar
Originally Posted by meirion1
Thanks for a quick response..Yes Bushey in Herts
I was going to buy the parts from www.bestpartstore.co.uk, based in Berlin. The rear sensor is the same price as the one you posted ion eBay.
I'm not a fan of using eBay I'm afraid.
I contacted a local jag garage today. to double check what they knew and they said without inspecting the wheel in question is could be either be, or possibly both:-
The sensor ring which is fitted around the axle and could be rusted up, and/or the rear sensor as you provided a link to.The ring must be fitted to either the rear axle or the wheel section,
which spins round as the care moves,, so one or both of these sensors must detect if and when both the wheel and axle are not rotating ( ie, wheels locking in snow etc) when in gear I assume.
Their explanation of the sensor ring rusting up , to me, would still not stop it from spinning, so I'm a bit dubious about their explanation.
So I called my local garage back and informed them of the possible issues. They mentioned they could fit a part which I provided but I wouldn't get their warranty cover on the part.( even though the cheaper one has one year's warranty).. Again, my local garage would still have to examine the car and see if it may be the ring sensor and/or the rear sensor.
On this occasion I will put this down to experience, and leave it to my garage to fix given it is a MOT failure.
Thanks for your help meirion1
Old Apr 13, 2019 | 05:39 PM
meirion1's Avatar
If there is a major problem with the reluctor ring, it can be replaced.
There is a firm in Lincolnshire who make them.
dsetter
Jun 17, 2025 02:32 PM
xdave
Sep 25, 2016 12:19 PM
03JagSType3.0
Sep 25, 2012 08:32 PM
