AC Compressor
2007 XJR AC compressor becomes inoperative after about 15 minutes. I checked system pressure and added 24oz of R134 to bring the pressure up to 50PSI from 48PSI (ambient temp at the time was 105). Radiator fan is running. After I let the car cool (overnight) the compressor will become functional. Note:engine temp (as indicated on the cluster gage) is mid range when the compressor disengages.
Subquestion: Will the compressor shut down if engine temp goes too high (even though indicated temp is normal)?
Thanks in advance for any suggestions on next steps.
Note: This is reposted on this forum after incorrectly posting on another forum.
Mark
Mark
