ACC Not Working; ICarsoft v3.0; Mongoose?
For years, I have been trying to fix "Cruise Control Not Working" error message with amber light on my 04 XJR.
I replaced the clockspring to no avail except that I now have a spare.
I have gotten a lot of excellent advice. I think the best is from 351x151 a while back:
"These are the codes associated with an amber light and "Cruise Not Available" message:P0566
P0567
P0568
P0569
P0570
P1697
The above all deal with bad steering wheel switches or a bad clock spring
P1571 Bad Brake light switch or relay
P1696 Can network failure or ASM module fail"
Using the ICarsoft V3.0, I get only the P111 message. Can I delete & have it scan again to pick up needed P code(s)? Otherwise, I get several U error codes when I do a "quick scan". The only relevant one seems to be in the anti-lock braking system scan: U2515 - Missing message for adaptive speed control.
Some have mentioned something called a mongoose cable. Is this added just to drive me crazier? Or, will it read the P Codes where my reader won't except for P111?
I think I could fix this if I can only get one or more of the aforementioned P Codes.
As always, your help much appreciated.
HAPPY BIRTHDAY AMERICA!!
P0567
P0568
P0569
P0570
P1697
KittyVet
May 31, 2020 11:57 AM
sweatyfox
Jan 19, 2017 01:10 PM
