Adaptive cruise control failed
Old Feb 7, 2012 | 11:44 PM
SuperTrav's Avatar
Phil Brody, I get the impression that you are a parts picker of the highest order. I used to find and broker used auto parts. Kudos to you for finding the part and then pulling the trigger when you found something that seemed close.
I am relying on my skill set to make XJ ownership viable for me. Without such tactics, I can't afford to play.
Old Feb 8, 2012 | 11:13 AM
xjrguy's Avatar
Originally Posted by phil brody
I was thinking the same thing about realigning the unit, but if everything seems to be performing flawlessly, why screw with it, especially if it's a Jag ? Where is this learning algorithm held, in the module, ecm or elsewhere ? and does it continue to adjust ? Thanks again for the info.
It depends, yours, I think, is early enough to be self-contained. That would make it ACC2. To clarify the situation. ACC1 and ACC2 had a single module fitted to the front of the vehicle. This module had both the electronics and the radar scanner inside it. When ACC3 was introduced the electronics were fitted in a separate module so that the module fitted to the front of the car houses only the radar scanner. ACC3 was introduced at the following VINs:
S-TYPE N00465
XK A39959
XJ [X350] All long wheel base vehicles are fitted with ACC3. The earliest Vin is G29365; however there was a mixed condition up until G34523 when all of the X350's were fitted with ACC3. For vehicle built between G29365 and G34522 you will need to check the part number on the electronic control module to ensure that you get the correct part. Also the connection on the ACC3 module is smaller than that fitted to an ACC2 module.
I believe the alignment initiated by IDS is a wider, more aggressive zeroing in, but that it is always narrowly fine tuning its alignment. I'm just not positive.
Cheers,
Old Feb 8, 2012 | 12:32 PM
Fitz's Avatar
Default If I ever find the ACC module . . .
Can I just plug it in myself to ensure it works before going to the dealer for alignment?
Anyone have a lead on one of these? I have contacted dozens of used parts suppliers.
Old Feb 9, 2012 | 07:48 AM
phil brody's Avatar
I would think so, placing it in the opening propped up by a screwdriver worked for me, since it is back on the network.
I did have to do quite a bit of hunting to find one. Unfortunately,I found many yards don't inventory these and crush them with the car, and I had to describe where they are located to all, but there are a number of XJR and XJ8's ending up at salvage auctions. Ridesaefly.com can reveal vins of potential donors. I believe all the XJR had the units installed, XJ8's as an option. Curiously, my unit had a part no. 2w93-9aa12-bd which there are about 4 google pages of chatter on, yet the replacement part I received 2w939aa12-be there is nothing. Perhaps they fixed the deficiency with the former high failure rate part, or at least I can hope.
And thanks again Steve for all your info !
Old Jul 7, 2012 | 09:09 PM
luv2fly's Avatar
Question ACC Module location 04 XJR
My 04 XJR has allegedly had the ACC unit replaced before I bought the car. But, it brakes for bridges, some, not all. Can't maintain a good distance, falls back then accelerates hard, then jams on the brakes. Has no one figured out how to defeat these blasted things so just the plain old cruise works? Where is the unit actually located so I can be sure its not blocked and aimed properly?
Tx,
Dale
Old Aug 2, 2012 | 08:00 PM
Bryn's Avatar
Well after a great deal of hunting I found an acc module in a boneyard from an 04 XJ8. $665 delivered, although it wasn't in the Vin range that was suppose to be compatible. I still can't believe this was plug & play. The unit looked nearly brand new. The only odd thing was that the number on my old unit was 2W93-9AA12-BD and the new one was 2W93-9AA12-BE I wonder what the difference is, or could this have been already replaced on the boneyard car ?
Phil have 2003 XKR needing ACC unit. Can you give any advice on where to look?
Old Aug 3, 2012 | 05:47 AM
phil brody's Avatar
Got mine from European Automotive in Georgia 229 890 0050 after hunting virtually worldwide online.
Old Aug 3, 2012 | 07:59 AM
  #28
Flstfi's Avatar
Bryn,
There is a European junkyard in central Indiana called Brickyard Autoparts. Give them a call at 317-831-2627.
Old Aug 3, 2012 | 01:00 PM
Bryn's Avatar
Default Acc unit
Thanks guys. I wish the XKR was as simple as the E!!!
Old Aug 3, 2012 | 03:47 PM
  #30
Bryn's Avatar
Default Acc
Got one (i hope) part number C2C023960, $300 from Chicago.
Old Aug 4, 2012 | 08:22 AM
  #31
phil brody's Avatar
Funny Bryn, I have a 70 e type too. Agreed it's definitely more straightforward not having to talk to modules. $300 is a great price if it works. I had many promises of shipment that didn't pan out. I think you have to pay some attention to VIN #'s as there seems to have have been a number of revisions on these but it appears there is some interchangeability. Good Luck
Old Aug 4, 2012 | 04:50 PM
  #32
Bryn's Avatar
Default Acc
Phil,
the dealer was good enough to confirm part number for me so i am hoping it all works. The guys at Quality Autoparts sound profesional so will see when i get the part. The Jag dealer has offered to install and align.
Must admit that i preffer driving the E, the R is much better all round but there is something about that torquey, longlegged feel about the E.
Old Aug 18, 2012 | 04:09 PM
  #33
phil brody's Avatar
So drum roll how'd you make out with the part from Chicago ?
Old Aug 19, 2012 | 11:40 AM
  #34
Bryn's Avatar
Default No go
i got a refund to my credit card and no explanation. i guess it was too good to be true.
i think what this company does is take the order then try to find a part?
Still looking.
Old Aug 20, 2012 | 07:38 AM
  #35
phil brody's Avatar
I had 2 or 3 of those experiences, always when it was too good to believe.
These have to start ending up in the yards soon,unfortunately most parter's
don't know what they are and crush them with the car. I was also going to use ridesafely.com to track
a car from auction to yard to see if I could find one but got lucky just
before.
Used and Salvage Auction for 2004 JAGUAR XJR | VIN: SAJEA73B74TG09832&
What's nice is you enter specific years and also see vin's to check
compatibility. I did register as it was free and no big deal.
Old May 8, 2013 | 12:10 PM
  #36
Robert Page's Avatar
Sorry to reserect this thread but my ACC has just gone bad and I am now in the same boat as all previous and I am not paying $6000+ for repair so my otherwise mechanically sound XJR could end up a parts car! I have contacts in the UK and I am traveling there in the next few weeks. Does anyone know where I may find one or any fixes that have panned out to get round this issue?
Old May 8, 2013 | 05:39 PM
  #37
meirion1's Avatar
Robert
Most x350 parts for sale on e bay uk are from JoJags they seem to break lots of x350's.
I believe they are in the Liverpool area
Skeeter
Sep 17, 2015 08:15 PM
Donzi
Sep 17, 2015 01:29 PM
adam699
Sep 12, 2015 05:32 PM
XFR_Gold
Sep 2, 2015 12:24 PM
